NI TestStand
Setting the Batch Model Options within sequence
TestStand 2.
I have two batch test sequence programs that run from the same TestStand Station, one needs the model option 'sequential batch mode' set and the other does not. How do I set this option programatically from within the test sequence rather than having to change the option each time I change test sequences?
(3,232 Views)
Ooops- Listen to James 🙂
Message Edited by AllenP on 02-12-2008 12:16 PM
(3,229 Views)
I haven't tried it, but it looks like you can right click on your sequences list, select Sequence File Callbacks..., add the ModelOptions callback and edit it, and insert a statement step with:
Parameters.ModelOptions.SequentialBatchMode = true
(3,228 Views)
