NI TestStand
Shared TestStand developer workstation
Hi all,
My team is composed by multiple TestStand developers.
They need to write and modify sequences on their own computer without running (debug on the manufacturing test bench).
Instead of deploying teststand and all sequences on all developers computers, would it be possible to create a workstation (under windows server or windows 11) where each developers would logon to run SeqEdit to modify or develop sequence?
Developers have to use teststand at the same time. In this case, each developer would run a teststand engine in parallel but each developer would have its own sequences copy.
Do you think it's possible?
Thanks for your help
(338 Views)
If you are using separate TestStand Environements, you can run parallel TestStand Engines (SequenceEditors) without any issues.
Using TestStand Environments - NI
Licensing is another topic you should check with NI.
CsBihacker
(300 Views)
