NI TestStand
Show CMD Line Window and write Standard Output in a TestStand property?
I execute a command line application for chip programming via Step Type "CallExecutable". I need to receive the output stream of the application to show it in TestStand report. For do this I configured the parameters in "Standard Output/Error" tab to values "Store in Variable/Property". Unfortunately in this configuration the Cmd line window will disabled. To give the operator feedback about programming process it would be a plus to show the Cmd line window nevertheless. Is there an ability to realize that? Thank you for help.
Best regards
Christian
Message 1 of 1
(283 Views)
