NI TestStand
Showing Result as Hex in TestStand v4.0
I'm using TestStand v4.0 & CVI v8.5 and having some problem with displaying hex result in TestStand.
In the code,
td->measurement = 0xAA; // td is tTestData passed from TestStand
In the TestStand step,
Limits -> Numeric Format is configured as "Hexadecimal" (%#x).
The limits were shown as hex. However, the test result was shown as decimal.
The same code & step worked in TestStand v3.5. Did I missed anything in the code / step?
Eric
(3,742 Views)
You have to format the Result.Numeric separately.
Do this by selecting Property Browser, then expand the Results and select Numeric. Then press right mouse click and select Numeric Format.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,729 Views)
I believe this was fixed in 4.0.1.  If it isn't, Ray's fix should work.
Allen P.
NI
(3,724 Views)
Thanks for your help. Ray's suggestion works. I also want to update TS to 4.0.1. I checked the http://joule.ni.com/nidu/cds/fn/p/sn/n23:4.33/lang/en, but I don't think the update was listed there. Can it be downloaded from NI website?
Eric
(3,702 Views)
See this post.
Josh W.
Certified TestStand Architect
Formerly blue
(3,699 Views)
