NI TestStand
Shutdown Teststand 3.1 Engine Hangs
I am using TestStand 3.1 engine in combination with Labview 7.1. Everything works fine until I run a sequence file. After this run the logout/login and the shutdown do not work anymore. The complete engine hangs. When I look at the description of the shutdown method it says;
<QUOTE> Closes opened sequence files and executions. This method also releases the TestStand Engine. <UNQUOTE>
So this
(2,954 Views)
see link http://forums.ni.com/ni/board/message?board.id=330&message.id=9566
for all further responses
Regards
Ray Farmer
(2,945 Views)
