NI TestStand
Simple UI Freezes on Exit - dynamical sequence call
I am using TS2019 with LV2017.
My Teststand always load a static sequence file, which dynamically (based on some conditions) calls sequences from other sequences files on the disc.
This architecture works totally fine with Sequence Editor, but when executed with the Simple UI example, the UI freezes as soon as the exit button is pressed after the sequence execution. This happens to both the LV source and the executable built from it.
Because if I execute an example sequence which does not involve dynamic calling of other sequence files, everything works fine. I wonder if this issue is due to the dynamic calling, and the simple UI is not able to close the opened reference related to it.
Anyone has any experience/insight to this.
Thanks!
Message 1 of 1
(1,389 Views)
