NI TestStand
Single step execution of a DLL func invoked by Testand
Hello, I have an issue regading the single step execution of a function inside a DLL. The library functions were created using CVI, but not using the Specify Module->Source Code->Create Code option from Testand.
To debug the application, I need to single step through the sequences - this works OK. I tried to create the sequences using LabWindowsCVI and C/C++ DLL adapters, but unfortunately I cannot single step through the code of the DLL function. Any information concerning this issue would be greatley apreciated.
I'm using Testand2.0 and LabWindows6.0.
Regards
(3,147 Views)
Hi miniMe,
You would have to launch your SeqEditor/SequenceFile from CVI after first specifying the External Process. the Link should help you.
Regards
Ray Farmer
Regards
Ray Farmer
(3,144 Views)
Ray, Many thanks for info.
Regards
(3,141 Views)
