NI TestStand
Skipped Teststeps
Is it possible to see all skipped Teststeps in a Sequence File about the menu or another function?
(2,871 Views)
Hey rooster,
What are you trying to do?  Just see the steps that are skipped?
If you search for Skip by hitting control-f then you will see a list in the find results window.  Also in the Settings column you should see the word Skip that will indicate if the step is being skipped.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,844 Views)
