NI TestStand
Something like subVI but for teststand
Greetings friday people.
I am quiet noob playing with TestStand, so please be patient with me. I would like to ask if there is some clever way to connect and hide a bunch of statements in TestStand. Like we do in Labview creating subvi to maintain high transparency of code and to be able to reuse it.
Thanks a lot for any suggestion.
Have a mice day.
jan
(2,424 Views)
There are two options I can think of depending on your intent. First, statement steps can include multiple lines already so you can have long complicated code show up as a single step that is copied and displayed as a single line item in the sequence.
Second, and more analogous to a subVI, is a Sequence Call step. This step executes a TestStand sequence as a step. You can make a library of simple sequences, and then reuse them multiple times in the MainSequence. Go to the TestStand Examples folder and check out the 'Parallel Testing Strategies' for this feature.
- Regards,
Beutlich
(2,407 Views)
Sounds great.
Thanx for your explanation.
j.
(2,368 Views)
