NI TestStand
Splitting a test in two
Currently I have a test that requires the cover to be installed on the UUT part way through. There are a lot of screws so this step takes several minutes. To increase test set utilization we would like to split the test in two so that the modules can have their cover installed elsewhere and thus allow the test set to start another board. However I am not sure how to marry up the data from the two partial tests as the current file name scheme is "modelNumber_[serialNumber]_yyyymmdd_hhmmss.html".
What approach would you use?
jvh
Message 1 of 14
(4,544 Views)
Hi
Just for more understanding are tests running on different machines ?
Is there a "master" Sequence that controls the two tests A and B ?
or do you need a Sequnce C that collects the report from A + B = C ?
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 14
(4,519 Views)
Do you run a Batch Process?
regards
Ray Farmer
Regards
Ray Farmer
Message 3 of 14
(4,516 Views)
Thanks for inquiring.
It is not a batch process, it uses sequential model. Currently there is one test subsequence running on one test station. The top level, main sequence allows one to choose the board type, inertialNav, laserAltimeter, squibFire, receiver, etc. The receiver subSequence has about 24 steps and I need to split it between steps 5 & 6.
jvh
Message 4 of 14
(4,510 Views)
Just to get the clear picture;
This receiver test sequence when it complete test 5 you what it to stop to allow the unit to be taken away freeing up the test system  to test another unit.
Then when you have done with the fitment, run the reciever test sequence again but continue on from Step 6 and at the end have the combined results of both runs.
Regards
Ray
Regards
Ray Farmer
Message 5 of 14
(4,507 Views)
Looking like that ?
Regards
Juergen
--Signature--
Message 6 of 14
(4,504 Views)
what have you been drinking, juergenSmiley Very Happy
Regards
Ray Farmer
Message 7 of 14
(4,499 Views)
When had i posted my stuff i saw/read your question (really good question!)
Seems have totally translated it wrong !
Oh Germans !
Juergen
--Signature--
Message 8 of 14
(4,495 Views)
No, just need to stop after step 5, come back later and pick up at step 6.
The idea is to run steps 1-5 on many boards, then after their covers are installed run the remaining steps.
Message 9 of 14
(4,489 Views)
Interesting task !
At the moment i have a really crazy idea !
But lets wait for Ray's suggestion before running wrong 🙂
Regards
juergen
--Signature--
Message 10 of 14
(4,485 Views)
