NI TestStand
StationGlobals.NewSubproperty
I am trying to set up a station global on the fly in test stand. The variable that I want to set up is a number. If it already exists I want to do nothing. I am trying to use the  StationGlobals.NewSubproperty. These are the properties I am passing in StationGlobals.NewSubproperty("Test", PropValType_Number, False, "999999", PropOption_DoNothingIfExists) but it does not work. Any help would be appreciated.
(3,408 Views)
Accepted by topic author mdcoco
It worked for me with the following:
StationGlobals.NewSubproperty("Test", PropValType_Number, False, "", 0x4)
Not sure what the 999999 you had is doing?  Also, I used 0x4 instead of the Property Option.  Seems more stable to me.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,398 Views)
Thanks !!
(3,389 Views)
