NI TestStand
StationGlobals.TS.CurrentUser disappeared
Hi all,
my CurrentUser container in StationGlobals => TS disappeared. I have no idea how this happened, I am not aware of deleting anything.
Now the question is how can this container be restored? It seems that I can not insert any elements below the TS container, neither by right clicking nor by moving something in TS.
Thanks in advance,
gedi
(3,615 Views)
I opened my StationGlobals and compared my TS container with your picture.  Mine looks exactly the same as yours.
Is the picture you attached your current setup that documents the problem?
Try clicking on the "+" next to the CurrentUser icon and it should display more details.
PH
(3,602 Views)
Hi PH,
this picture now shows the empty TS container. The CurrentUser, like in the last picture, is missing, and I have no idea how to insert a CurrentUser container again.
gedi
(3,564 Views)
Hi
The Station Globals are saved to disk when the current instance of the TestStand Engine is closed.  This happens anytime you close the TestStand Sequence Editor or a User Interface.
Station global variables are stored in the StationGlobals.ini file located at:  <TestStand>\Cfg directory.
(3,485 Views)
