NI TestStand
StationGlobals across multiple clients
One more question :  If all 4 clients are trying to write or read the variable at the same time, is that going to cause any problems? Is this process managed by Teststand?
Message 11 of 15
(949 Views)
It is managed by TestStand but you'll still need to be aware of the risks of having multiple threads/executions accessing shared data. Perhaps you could use seperate variables for each client rather than trying to share data across all clients...
CTA, CLA, MTFBWY
Message 12 of 15
(946 Views)
StationGlobals is intended to cover any Station requirements that need to be shared between multiple test clients running in a single TestStand application and that only one TestStand application runs on a system.
It sounds like you are running multiple TestStand applications on a single system. Is this correct?
Regards
Ray Farmer
Message 13 of 15
(944 Views)
Yes, I could do that, but it would involve more changes to my code, which I am trying to minimize to meet my deadline.
Message 14 of 15
(942 Views)
No, I am just running one Teststand sequence, but 4 instances of it.  Each instance is used to test the same type of DUT.  I was just wondering if there is any way to access the the StationGlobals value modified in one instance by the other instances during run-time, without having to re-load all the StationGlobal variables.  Is there any way to reload a specific StationGlobal variable at run-time?
Message 15 of 15
(941 Views)
