NI TestStand
StationGlobals.ini has been modified outside of the sequence editor do you want to reload it
As my subject says, I have heavily modified the uutdlg.c and modelpannels.uir because I need to have StationGlobals.ini with different uut part numbers. Is there a way to programmatically do this so that my operators will not have to respond to this prompt?
Thanks in advance
Michael
Message 1 of 9
(4,633 Views)
Can you describe what you are doing to StationGlobals.ini in those modifications?  There might be a better approach.
Message 2 of 9
(4,629 Views)
Changing the uut part number
Message 3 of 9
(4,626 Views)
Can you describe how you are doing this?  UUT Part Number is not a default variable set in here.  Are you modifying the file directly?  Are you using the TestStand API to change it?
Message 4 of 9
(4,623 Views)
 AllenP Wrote: Can you describe how you are doing this? I have heavily modified the uutdlg.c and modelpannels.uir because I need to have StationGlobals.ini with different uut part
AllenP Wrote: Are you modifying the file directly? Yes
AllenP Wrote: Are you using the TestStand API to change it? No
Message 5 of 9
(4,618 Views)
Can you give any more detail on how you are actually modifying the file?  Are you forcing it to be saved?  Are you changing the ini file directly?  If you are just using the TestStand API to modify a Station Global, you would not get this dialog.  I would recommend investigating why this is happening rather than trying to work around the problem.  It may be as simple as the file being saved in the dialog (which is not necessary if you are using the same Engine to modify the values).
However, if you wish to disable this option, you can set the ApplicationMgr.AutomaticallyReloadModifiedFiles property.  You would have to get the ApplicationMgr ...
Message 6 of 9
(4,612 Views)
AllenP wrote: Can you give any more detail on how you are actually modifying the file? I open the ini file in "C" parse till I find the part number key. if it doesn't match what the operator clicked on I reopen the file and save it. I'm using TestStand 3.0 and I have tried to find an examples of how to do this with the TestSand API with no luck. The examples I have found aren't compatibale with 3.0 & can't up grade company will not pay for it.
Message 7 of 9
(4,596 Views)
If you are using 3.0, the suggestion about using ApplicationMgr will not work as the 3.0 Sequence Editor did not use this control.
The best way to avoid the problem is to use the API to change the variable values.  I would not recommend directly editing the INI file.  Instead, you will need a SequenceContext passed into your code.  If you have modified the default model code, chances are a SequenceContext was passed in to the entry point you are using.  From there, you will need to call SetValNumber or SetValString or similar function to set the value you wish.  That API was available in 3.0 and will allow you to not have to save the StationGlobals.ini file.  If you are having trouble, a small example or description of the problem you are getting would be helpful.
Message 8 of 9
(4,584 Views)
I figured it out.  A simple example would have helped ie:
  int      error = 0;
  ERRORINFO    errorInfo;
  ErrMsg   errMsg = {'\0'};
    int flag = 0;
    char *stringVal = NULL;
    tsErrChk (TS_PropertyGetValString(context, &errorInfo, "StationGlobals.MYUUT_PN", 0, &stringVal));
   if ( strcmp(stringVal,stringFromPanel) != 0 )
           tsErrChk (TS_PropertySetValString(context, &errorInfo, "StationGlobals.MYUUT_PN", 0, stringFromPanel));
Message 9 of 9
(4,543 Views)
