NI TestStand
Step.RecordResult
I have unchecked the "Record Result" box in the "Run Options" properties for one of my pass/fail tests that I do not want displaying results (for security reasons).  I wanted, however, to control this with a boolean based on some user input at the beginning of the test.  So, I thought I could set "Step.RecordResult" in the Espressions (I tried Pre and Post), but it didn't seem to work.  Is this the correct approach to setting this programatically?
(4,194 Views)
(4,182 Views)
