NI TestStand
Step.Result.Status
Why can't I see this variable during runtime?  I certainly can see it before I launch the application.  Where do I have to go to see it?
Tony
(4,223 Views)
Try
RunState.Sequence.Main[<your step name goes here>].Result.Status
or
ThisContext.RunState.Sequence.Main[<your step name goes here>].Result.Status
.Main part assumes the step is in the Main Step Group, but this can be replaced with ".Setup" or ".Cleanup"
Regards
Steve
Message Edited by SercoSteve on 03-01-2006 08:40 AM
There are 10 types of people in the world that understand binary, those that do and those that don't.
(4,213 Views)
You can't see Step.Result.Status in the context tab while at a breakpoint because breakpoints occur between steps, thus there is no Step property at that time even though it does exist while a step is running.
However, you can inspect the value of RunState.PreviousStep.Result.Status in the context tab.
(4,196 Views)
