NI TestStand
Step Type ActiveX/COM
Hi!
I want to know what is exactly ActiveX/COM step Type. I don't know what kind of program produce this type of step.
Capblans
(3,913 Views)
You would use these step type to interface to the methods and properties of an activex/com object.
Tpyically you would use this step type to interface with the TestStand API methods and properties. Also code generated using Visual Basic.
There is a couple of articles (application notes) here that maybe helpful.
Within the TestStand\examples folders and on the NI website are examples using the ActiveX/COM adapter
Regards
Ray Farmer
Regards
Ray Farmer
(3,906 Views)
Thanks for your reply!
In fact I want to know if step ActiveX/com can be use wirh Matlab code.
(3,905 Views)
I know you can interface with matlab using labview and therefore you could use the LabVIEW adapter instead of the ActiveX/COM adapter.
Dont know if you can directly interface with matlab from TestStand.
Regards
Ray Farmer
Regards
Ray Farmer
(3,899 Views)
Thanks!
So if I great understand I can integrate Matlab module code using the Labview Adapter.
Thank You very much!
Capblans
(3,895 Views)
Just had a look at the Matlab website here, there is a Matlab builder for COM.
Therefore its possible you maybe able to interface direct from teststand via the ActiveX/COM adapter.
Regards
Ray Farmer
Regards
Ray Farmer
(3,891 Views)
