NI TestStand
Step by step in cvi dll
I want to run step by step in a function which is in a cvi dll. Is it possible ? I have done a cvi debug dll which I used in my TestStand project. But I do not manage to run step by step inside the function in dll.
(3,367 Views)
You have to configure the CVI Adapter to execute steps "in an external process of CVI". Then, you can debug the CVI DLL function by stepping through it.
Norbert
Norbert
Expert: Geometry
(3,361 Views)
Another alternative is to run seqedit.exe or your UI as the process to debug from the CVI development environment, then you can either set a breakpoint in your function or on the step in the sequence and then do step into.
Hope this helps,
-Doug
(3,349 Views)
Accepted by topic author sfla
Ok, it works. Thanks a lot.
(3,347 Views)
