NI TestStand
Step list configration
hi guys:
    i met a question when i was trying to config the step list , i want to add a row to show the dynamic results , how can i do?
thanks
(3,597 Views)
Hmm, I know that you can easily embed dynamic results into the Description column of your steps... but as far as having a second row...?
The only way I know of currently is to use the API to edit your step's "comment" text on the fly, which would get you the look you want but I don't know if I'd reccomend it as it might lead to other development/maintenance headaches.
Even if you add appropriate line-break symbols into your name/description text, the step view seems to strip them out when rendering the text into the the display, so this may be an R&D question.
Is there a reason why you need the second line?  You might just want to consider adding another column to the Left/Right of the step's name if you're trying to isolate out the discrete information you're trying to display?
Cheers,
Elaine R.
www.bloomy.com
(3,580 Views)
Above is my expect layout ,every step has its own low/hight limit ,and result .it is laconic and clear, l like it.
Now the question is :  i need to add a columns which has almost the same function as "Status" , i guess i need the type "Expression", but i don't know how to feed a variable , and refresh the display before/after a step or sequence
Message Edited by adobefree@gmail.com on 11-11-2009 08:36 PM
Message Edited by adobefree@gmail.com on 11-11-2009 08:38 PM
(3,563 Views)
i have tried to feed a string variable to the expression directly , but these columns can't refresh automatically once the UI was build , it  was always a fixed string even i change the value before each step.
(3,559 Views)
hmm, try posting a UIMsg_RefreshWindows message after you change the property value that the expression refers to.
(3,543 Views)
