NI TestStand
StepIn StepOut StepInto ActiveX Buttons
Here there a way to have StepIn StepOut StepInto ActiveX Buttons in a LV OI just like the terminate button ?
Or trough the TS engine with some methods ?
Sebastien
(4,952 Views)
Just use the TestStand UI Button Control and connect it to the ExecutionView Manager with the CommandKind_StepInto, etc...
Attached is an image.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,949 Views)
OK nice thank you !
But which is the best :
1) Customize a LV button. Connect a TS button like you said, and hide it. On the LV button value change event do a DoClick on the TS button.
2) Customize a LV button. Using the StepInto/Step... methods of the execution class on the LV button value change event.
3) Connect a TS button like you said, and show it (no icon on the button...)
4) Are the TS UI Debug Controls (the same as in the TS editor) available somewhere ?
(4,938 Views)
Accepted by topic author PragmaTest
Option 4 the answer is no.
I would go with option 1 over option 2.  Because the ActiveX inherent functionality is a lot better than you could ever develop yourself (Option 2 is out).  No offense to your programming skills.  It's just a waste to re-invent the wheel.
This leaves us with Option 1 vs Option 3.  Personally it depends on the look and feel you want.  If you want a custom look then go with Option 1.  I've done that in the past with UIs and haven't had issues.  Option 3 will update the button text for you but you won't have the pretty icons.  Plust Option 3 is the easiest to implement and requires the least amount of maintenence.
Hope this helps,
jigg
CTA, CLA
testeract.com
(4,932 Views)
