NI TestStand
StepResult is empty
I have overridden the SequenceFilePostStep Callback and send an user defined UIMessage to call an Event in C# that I named "StepDone".
In StepDone I've got a reference to the current Step. I want do get the step.ResultStatus but it is empty.
So I have tried the SequenceFilePostResultListEntry Callback. There is the Parameter "Result" but this is an Container, how do I get the content of the Container?
I'm using TestStand 3.5 and C# and VS.Net 2005
(3,207 Views)
Code 1 (Callbackhandler UIMessage):
private void executionMgr_UserMessage(object sender, NationalInstruments.TestStand.Interop.UI.Ax._ExecutionViewMgrEvents_UserMessageEvent e)
if(e.uiMsg.Event == 10006)
Step niStep = (Step)e.uiMsg.ActiveXData;
System.Diagnostics.Debug.WriteLine(niStep.ResultStatus);
niStep.ResultStatus is empty. The UIMessage is send in "SequenceFilePostStep"
Message Edited by EddyAnt on 08-02-2006 08:26 AM
(3,193 Views)
