NI TestStand
Stepping into DLL code from TestStand
Is there any way to find out if a function in a DLL has been activated by the "Step Into" command of TestStand? (I am using the DLL flexible prototype adapter). I want my DLL function to behave in a different manner if you step into it than stepping over. In the first case, it should output some debug data in a special window. This has nothing to do with debugging the DLL in CVI, I know how to do that and it works fine. My question is: Is there any way to ask TestStand via the SequenceContext how it was called (Run, Step Over, Step Into etc....)?
Mike
(3,478 Views)
Hi Mike,
You can obtain the run mode of a step from its hidden properties eg Step.TS.Mode
Under the Menu | Configure | Station Options - select Preferences Tab. You can enable the show hidden properties.
Regards
Ray Farmer
Regards
Ray Farmer
(3,478 Views)
Hi Ray,
the Step.TS.Mode property tells me only if the step is executed normal, is skipped or forced to pass/fail. The information about stepping over or into cannot be retrieved from this property. I also tried to use the Execution Run States (Paused, Running, Stopped), but it always says "Running". Hm.... any other idea?
Mike
(3,478 Views)
Hi Mike,
Unfortunately there is no way to extract this information. I will definitely make a note of this and notify the developers of the issue, so that we may implement it in future versions of TestStand. Sorry for any inconvenience.
(3,478 Views)
Did you find a solution to determine how a step was called ?
I want to write a custom step type with special behaviour when called with Step Into.
(3,478 Views)
