NI TestStand
Stop Step from logging
Hi
How can stop a step from logging to the database?
Help share your knowlegde
(3,823 Views)
In the step properties, clear the Record Results check box.
Regards
Ray Farmer
(3,818 Views)
Sorry about the dumb question.
I figured it out just after i posted the question on the forum.
(3,816 Views)
Is it possible to stop the logging of a Call Sequence Step but the contents of the step must be logged?
(3,815 Views)
No. You will have to process the results afterwards to remove the SequenceCall step result but keep the actual results of the sequence.
I think even if you discard the step's result in the SequencePostResultList callback sequence you will still loss the actual subsequence results.
Regards
Ray Farmer
(3,809 Views)
