NI TestStand
Strange thing in Teststand
It's definitely strange when I got to find out in file globals of attached seq file. It's hard to explain here and please see the attached screenshot.jpg
Thanks in advance
Jacky
(3,762 Views)
Hi
You get this affect if you dynamically delete elements of an array. eg if your original size was 5 and you deleted the first two elements. The remaining element(s) don't start at index 0 but remains at 2 to 4.
Are you sure the attached seq file is the correct one for your JPG. I would have expected to find two fileglobals named "A" and "B".
Regards
Ray Farmer
Message Edited by Ray Farmer on 04-05-2007 09:23 AM
Regards
Ray Farmer
(3,752 Views)
Does "dynamically delete elements of an array" mean to delete programmly, rather than manual deletion? Is tha right?
Thanks!
Jacky
(3,746 Views)
That's correct.
Ray
Regards
Ray Farmer
(3,744 Views)
    I found another reason for this, that is to have set PropFlags_Hidden flag.
Thanks!
Jacky
(3,742 Views)
