NI TestStand
String Drops Blanks After Hyphen
I am trying to send a folder path from a variable in TestStand. The path unfortunately has a few spaces and a hyphen which is returning the wrong string.  The string variable contents are inside the angle brackets <"\\Six_Position_Flash_Programmer - Extra DIO\\Flash\\Datalog">. See attached image to see the outcome. There is nothing wrong with my my sequence as I use it with dozens of other folders and locations. I tried to break up the internal blanks and replace them with a +" "+ but that didn't change the outcome. What can I do here?
(1,321 Views)
I don't have python so I can't test this but 2 things I can think of:
Option 1 - Try putting an escaped space in there? \s
Option 2 - Put an @ symbol before the string @"\\Six_Position_Flash_Programmer - Extra DIO\\Flash\\Datalog".  You'll need to remove the double slashes to just single slashes if you do.  The @ symbol basically tells the string to not do escape characters.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,277 Views)
I tested it with LabVIEW. It seems to be working as expected. You could try implementing Jigg recommendations
Dharani | CLA | CTD
Dharani | CLA | CTD
(1,255 Views)
