NI TestStand
String Value Test: Evaluate Data Source against multiple values?
In a String Value Test, is there a way to evaluate one Data Source against multiple string acceptable values (in Expected String Value)?  Basically, I need a test the where the results "D:", "E:", "F:", or "G:" are acceptable, but "C:" of <blank> are not.  I feel like this should be simple, but my brain is fried today...
(6,967 Views)
It's kinda hacky but it works.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(6,966 Views)
I was gone for a day, so I'm just getting back to this.
I can't open the sequence, because I still have TesStand 4.2.1.83.
Thank you for your help,
T
(6,925 Views)
I back saved it.
jigg
CTA, CLA
testeract.com
(6,923 Views)
Thank you jigg, that works.
I am going to revise it to use an array variable for the acceptable letters.  I'll post when I get it working.
Thanks again,
T
(6,918 Views)
You may be able to do that.  Let me know how it turns out.  If you had 2014 or newer it would be trivial because they have a Find function for the Arrays.
jigg
CTA, CLA
testeract.com
(6,913 Views)
Nice thanks 🙂
I needed Step.Result.String == "Pass - Concession"? "Pass - Concession" : "Pass"
(6,021 Views)
