NI TestStand
String formatting functions for ASCII Reports in TestSatnd 4.0
I am trying to create ASCII text reports that shall contain a list of instruments and their parameters in a tabular form (as shown below). Is there any function available for string formatting that is readily available to format the strings in a way that they are alinged in a way to give a tabular look. Using "\t" between the details listed gives a very uneven look.
Name         Param1        Param2       Param3      Param4       Param5
Instru1        Xxxx            XXXXXX       X                 XXXXXX        XXX
Instru 2       YYYYYY      YYYY             YYYYYY    YYY               YYYYYY
Saranya
Message Edited by SaranCh on 04-23-2008 12:32 AM
(3,271 Views)
You could use Str() to put strings within fixed width columns. Examples for left and right justification:
"|" + str("MyValue","%-40s")+"|"
|MyValue                                 |
"|" + str("MyValue","%40s")+"|"
|                                 MyValue|
(3,257 Views)
Thanks!! This one works.
(3,237 Views)
