NI TestStand
String value test will not go passed
Not sure what version of TestStand you are using, but recent versions have an API Engine.Utility.Escape() that you can use to convert your string limit into a correct TestStand expression string literal. Just use this Engine.Utility.Escape() method with the EscapingOption_SurroundedByQuotes option to convert your raw string into the correct format for use with a TestStand expression, such as the string limit.
Hope this helps,
-Doug
Message 11 of 13
(1,085 Views)
Yhea !!
Thats Dug9000 i know!
I have installed T4.1 and checked out this new feature
So misha lets keep it simple ....
greetings
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 12 of 13
(1,065 Views)
I found that cutting and pasting the string from the LabVIEW indicator into a local variable first and using the local variable in the comparison will work.
Jim
Message 13 of 13
(1,052 Views)
