NI TestStand
Sub sequence Populate Parameters
Hi
I got a callback in the bacth model which has a parameter. i then use this callback in my sequence. i want to populate this parameter in my sequence so the it can change this in the batch model.
How do i do this?
By simply writing to the parameter does not effect batch model referenced parameter.
Help share your knowlegde
(3,012 Views)
Is the parameter you passed is "passed by reference"? If it is "passed by value", the changes wont reflect back.
Regards
Ranjith Naduvil
Regards
Ranjith Naduvil
(3,009 Views)
