NI TestStand
Suggestions for Optimizing Preload?
I have a few questions in regards to Preload options for TestStand.  I am writing a custom user interface with the NI TestStand UI Controls.
1. When loading large sequence files, TestStand does not display progress and appears to "lock up" both TestStand and LabVIEW.  Is there any way to display progress during preload?
2. Is there a method to Preload sequence file steps that could be called in the background while the user is doing other tasks?
I have attempted to "Run" and abort immediately, but this generates a failure report in addition to locking the LabVIEW UI while the preload occurs.
Any advice would be greatly appreciated!
CLA, CTA
Message 1 of 11
(5,149 Views)
All code modules have to be in memory when the execution is calling them.
That being said, you have to invest the time to load the modules.
What can you do in order to reduce the initial loading time?
Distribute the loading of the modules to different locations. You can do this by setting different "load options" in your sequence for each module.
The possible selections are:
Preload when execution begins (default): Loading takes place in the first run if the module is not already in memory.
Preload when opening sequence file: Loading will be done when you load the sequence.
Load dynamically: Loading will be done when the execution enters the step and the module is not already in memory.
hopt his helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 11
(5,140 Views)
Thanks for the response Norbert.
I was already aware of how code module loading (preload) operates.  However, I am looking for solutions to the questions #1 and #2 above.
CLA, CTA
Message 3 of 11
(5,130 Views)
If you set the Options for the VIs in a sequence file to 'Preload when Opening Sequence File' the interface will 'lockup' after you call the
ApplicationMgr
OpenSequenceFile Method.
While there is no way to determine exactly how much time it will take for this to occur, what I do is simply start a progress bar before calling the method and then close the progress bar afterwards.  The progress bar will be continuing to run BUT will still give the Operator some indication that the application is not locked up.  We had issues where the operator thought the application would hang on opening large sequence files.
Using the default 'Preload when execution begins' will 'hang' TestStand when the Executions starts.   We used a UIControl to start the execution so it is not as easy to add a Progress Bar to the code becasue the UIControl execution is not contained in a event structure but is behind the scenes.
See attachment for my progress bar,
PH
Message 4 of 11
(5,126 Views)
Teds,
I have actually implemented similar code upon the EntryPoint1 (Single Pass) button click.
My sequence steps use the "Preload when execution begins" and "Unload when sequence file is unloaded".  It appears your sequence steps are using "Preload when opening sequence file".
The issue I have with the progress dialog is the LabVIEW interface seems to stop redrawing upon clicking "Single Pass".
  • If you minimize to the desktop while your "progress dialog" is displayed (Win+D).  Then re-display (Win+D again) does your dialog display properly?
  • Could you post your progress dialog?
CLA, CTA
Message 5 of 11
(5,121 Views)
I recommend you consider posting the idea of adding progress indicators for preloading to the TestStand idea exchange.
http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/idb-p/teststandideas
-Doug
Message 6 of 11
(5,119 Views)
Are there any suggestions for displaying a dialog while preloading occurs?  Is there a certain execution thread the VI should display in?
Currently, it appears the system is "locked up" as described in my previous post.
CLA, CTA
Message 7 of 11
(5,000 Views)
LVB
Your system only appears locked up when the user minimizes to the desktop? WIN +D?
I noticed in my implementation that clicking on Win + D causes the progress bar to stop and the operator interface window appears hung, at least most of the time.    Normally, it works fine and the progress bar increments.
I used a progress bar with an Above Normal Priority but it has the same Execution system as 'same as caller'  I spawn the VI using VI server.
You could always play around with different priority and Execution settings.
PH
Message 8 of 11
(4,996 Views)
The system always appears locked up.  Sometimes for up to 5 minutes due to the size of the sequences.
CLA, CTA
Message 9 of 11
(4,985 Views)
Here is my attached Launch VI and progress dialog VI.
This project is from TestStand 4.0 and LabVIEW 8.5
PH
Message 10 of 11
(4,950 Views)
