NI TestStand
Support for TRX file output
Is there any support for TestStand to output results in TRX format?  I found a post from 2008 but I'm hoping things have changed.  Surely we can't be the only company that wants to upload our teststand results to Visual studio.
.trx is the Visual Studio test results file format - its basically xml.
(3,062 Views)
Hi Brian,
Unfortunately, TestStand currently supports only the following formats to generate reports: atml, xml, html and txt.
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(3,026 Views)
