NI TestStand
Support of ATML TestDescription in TestStand
Hi
From the information on the website and forums, I cannot decisively conclude if TestStand 4.0 already offers out-of-the-box support for the import and export of ATML TestDescriptions.Thus, how would I, for example, currently accomplish the needed export of ATML TestDescription in TestStand?
In case there is no built-in support for ATML TestDescription yet, I would be glad if someone could tell me if and when NationalInstruments intend to implement it.
Thank you very much in advance.
Message 1 of 8
(4,087 Views)
Hey Tubinh,
I am attaching the ATML document that ships with TestStand.  I'm not sure what you mean by TestDescription?  TestStand has the capabilities to write ATML Reports based on the results from your test.
Hope this helps some.  If you have more questions don't hesitate to post.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 8
(4,077 Views)
Hello jigg,
thank you for the quick answer, but I was referring to the ATML Schema 'TestDescription', which should be used to export the test sequence file from TestStand to an ATML-format or import it back into the application.
Tubinh
Message 3 of 8
(4,071 Views)
Hey Tubinh,
In TestStand 4.0 I know that you can save to 3 different file formats- INI, XML and binary.  I don't know if the XML format can be formatted to be used in ATML or not (since I don't know enough about ATML) but I'm attaching an XML formatted Sequence File if you want to see what it looks like.
jigg
CTA, CLA
testeract.com
Message 4 of 8
(4,065 Views)
Tubinh,
Do you mind if we contact you offline?  I can get your email address you registered the account with so you don't need to publish it if you post that its ok.  If you have a different email address you would like for me to contact you with, please leave that in a message.
Allen P.
TestStand R&D
Message Edited by AllenP on 11-07-2007 10:17 AM
Message 5 of 8
(4,055 Views)
Hi Allen,
Sure, you can contact me offline. You can reach me with the email address I used to register my account.
Tubinh
Message 6 of 8
(4,042 Views)
@ Allen: you wanna contact me offline, however I have never heard from you since the last message in the forum.
I wanted to ask: On the website http://zone.ni.com/devzone/cda/tut/p/id/6100 it is written that TestStand provides an Interface-Framework for the use of Industry Standards like ATML in the area of test sequences.
Since there currently is no direct export of TestTand Sequence to ATML, I wanted to ask if there is at least an example for the mapping of TestStand Sequence File to the ATML TestDescription File? I.E. a TestStand Sequence file and an corresponding (equivalent) ATML file.
It would be very helpful for me if any of you could provide me with such an example.
Thanks in advance
Message 7 of 8
(3,962 Views)
Tubinh,
I was planning on having a colleague more involved in ATML contact you.  Unfortunately he has been out of the office.  The short answer is that we do not currently have support for ATML Test Description.  Due to the complexity of Sequence Files, it is difficult to export them to ATML  TD without losing information.  However, we are looking into being able to read ATML TD files and use them in TestStand for a future version.
Allen P.
NI
Message 8 of 8
(3,946 Views)
