NI TestStand
Suspected Memory Leak from CVI
I am calling a function from a DLL created by CVI/Labwindows in TestStand. When I run this function couple of times the PC crashes and believe it is something to do with memory leaks. I am freeing the memory of local variables created in CVI, but there is a string returned to one of the parameters from my function in CVI to TestStand.
I have look at this document that hints about memory leak between CVI and TestStand:
But I am not sure how can I do that in my function as I need the argument returned to teststand.
Attched is my CVI function and Test Stand file.
Does any body have any idea how to prevent this...
mama007
(3,535 Views)
Hi
As you do not use any TestStand API function in your code they cannot be the reason for the crash(es).
Your DLL takes a parameter "char Data[750]" but your function body does not care about the length it might get: Instead you use strcat() without doing any length checks. Maybe you exceed with these strcat operations the your string's memory?  That would be a good candidate for your problem.
Regards, Guenter
(3,526 Views)
Hi Guenter,
The document 2MRBTCY6 tells Test Stand allocates new memory to pass/receive information from/to CVI.
I suspect if this is not cleared, it can cause memory leak. I am not right?
I am using  char Data[750] for returning information back. The function already returns a value,which in my case number of events and I also want to pass the data back as well. Thats why I used this as a return argument.
So you can assume Data[750] does have blank/garbage in it when passed,and filled with actuval data I need when the funtion is finished.
mama007
(3,517 Views)
I have checked again and thinking it might not be memory leak between Teststand and CVI, instead memory leaks in CVI itself.
I have modified this function to the following simple call. and when I run this function many times, I didn't have any problems.
int _stdcall _export readserialport(int COM_Port,char COM_Data[500])
 int n=0;
 n = ComRdTerm (COM_Port,COM_Data,500,00);  // 00 -Event Termination byte
 return n;
But when I have added the line COM_Data=strcat(COM_Data,"end"); before return, Teststand crashed.
I feel the memory leak is the way the function strcat() works; ANy body have any clues...
(3,509 Views)
Are you using TestStand 3.5?  If so, turn on your debug options that check for memory corruption.  It appears you are using strcat to add to a string without checking the bounds of it.  You very well could be going over the 750 byte buffer you create when calling the function.
Allen P.
NI
(3,493 Views)
