NI TestStand
Switch Step Scan List
I am using the 2530B with dual 64x1 topology. In TestStand, I want to set up the IVI Switch Step to where it connects a channel off of each bank and then uses the DMM to record. In LabWindows I can use: "ch0->com0 & ch64->com4";
How would I do that using the IVI Switch Step? Under 'configure scan' then ScanList tab, I currently have ch0->com0 then ch64->com4 using No Action so that each set before DMM measures then each will disconnect with there own commands. Is there an easier way for this, although I have not tested this method? Forgive me if this seems common knowledge but this is first time I am using TestStand.
(3,054 Views)
Are you asking about an easier way to disconnect the switch? If you could clarify some more about what you are trying to do, that would be great. Also, are you using Switch Executive?
Jacob R. | Applications Engineer | National Instruments
(3,022 Views)
