NI TestStand
Switching: How to use NI Switchexec without predefining routes?
i am using TestStand 2014SP1 and Ni SwitchExec. In there i imported a 4x32 matrix.
How can i use the matrix in TestStand with the names that came with the driver without predefining routes?
Something like
Routes to Connect: "VirtualDeviceName.LogicalName.s1m1c1->VirtualDeviceName.LogicalName.s1m1r1".
Is this possible?
I think there is no way to predefine all possible routes for a 4x32 matrix.
Thanks for help
(3,885 Views)
Accepted by topic author OnlyOne
Solved.
The Syntax is
%LogicalName%/%From%->%To%
%LogicalName%: Defined in NISW under IVI Drivers + LogicalNames (which is refering to the Driver Session)
/: fixed slash
%From%: Create a new VirtualDevice and add the LogicalName to it. Then all possible names are visible. For example 1001COM
->: fixes arrow
%To%: Create a new VirtualDevice and add the LogicalName to it. Then all possible names are visible. For example 1001NO
example:
MyLogicalName/1001COM->1001NO
(3,878 Views)
