NI TestStand
Syncronization Difference between Lock and Batch Sync Serial
In the synchronization  Settings,
if a Lock is used for a step & the Batch Syncronization is  set to Serial (one thread at a time)
the AutoSchedule.seq(Sequntial-Sub seq ) is an example for this.
(4,985 Views)
What exactly is the issue with this? Lock and Batch Sync Serial do not do exactly the same thing so it's not surprising they don't have exactly the same behavior. The order in which threads are woken when the lock becomes available is likely different for example. Batch Sync wakes threads in test socket order, while a lock is first in first out.
-Doug
(4,979 Views)
thanks Doug
(4,928 Views)
