NI TestStand
System ExecutionEngine Exception
I would like to know when TS ExecutionApp Domain can throw an System ExecutionEngine Exception.
I am trying to run tests defined in a VB.NET class library (DLL) with NI's VB.NET
simple operator interface. I tried to debug the problem in Visual Studio environment
and each time it runs OK and I am not able to reproduce it in the debugging environment.
But the problem occurs when I run it outside the Visual Studio Environment.
Does any body face this problem before?
Thanks in advance for your reply.
Mano
(3,865 Views)
I forgot to give these info
TestStand Version 3.0
Visual Studio.NET 2003
Windows XP
(3,862 Views)
Hello Mano,
I am not sure what TS ExecutionApp Domain refers to. Nor do any of the the other Application Engineers who support TestStand. Could you please clarify what this is? Also, what is the error message you are getting? What seems to cause the error (ie: loading a sequencefile, starting an execution, etc)? I would like very much to be able to help you with this situation. Could you please provide a bit more detailed description of what the problem is?
Aaron B.
(3,839 Views)
