NI TestStand
System Integrity Script
Presently we are running TestStand 3.0 with LabWindows/CVI 7.0 in a multi-threaded environment.  We deploy these systems throughout the world.  Occassionally we have to re-image a drive for unknown reasons.  Something within either TestStand or LabWindows goes belly up.  Do you have script I can use or at least identify to me the key files I need to ensure sytem integrity?  I'd like to run this to ensure we have what we are supposed to have.  Your thoughts on how I can approach this.
Tony
(3,003 Views)
Hey Tony,
All the necessary files should be included with the installer.  However, maybe we can help you find the root of the issue.  Does it only happen on certain environments?  Like when it does happen is it on PCs that are running the same software?  What kind of behavior do you see when it starts happening?  Are you saying that the whole OS goes bad when this happens?  Is it a CVI OI? If so check this out.
Sam Roundy
NI
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,987 Views)
