NI TestStand
TDM , Diadem & Teststand Issue
Hi all,
1. I have to save result of Selected Steps  for each UUT in  TDM format (Analysis to be done in Diadem).
2. Each Step has a different Result out  (Current Measurement , Boolen out,  Arrays or  sometimes multiple results.)
3. My plan till date is to use the "SeqFilePoststep"  Callback  and Add  the results from previous step
4.  Has anyone achieved   satisfactory results with above mentioned method.
5.  well all UUTs (result) will be saved in the same TDM file.
Are there similar examples  or has any one tried the same.
(4,754 Views)
Hi aparab,
TDM is a file format for measurement values, so not necessarily meant to store execution results of a TestStand sequence execution.
So in short:
No, there is no plugin or whatsoever to create a TDM file storing results of a TestStand test.
You can implement your own plugin for this, but it will be a bunch of work and i question the content of that TDM file.
If you want to store measurement values in TDM (raw data used by TS to determine the result of the DUT), you should use the module to save those values in TDM(S).
hope this helps,
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(4,700 Views)
Hi aparab,
If you continue down this path of writing to TDM file from TestStand, then I'd recommend you write a new TDM file for each UUT.  There are only 3 levels of hierarchy in TDM, so it's best to reserve the Group level for the Step and the Channel level for the Measurement.
The easiest way to do this, though, is to write ATML data files directly from the TestStand process model.  You can use the posted ATML DataPlugin to index the results and query-load them into DIAdem for analysis and reporting.
Brad Turpin
DIAdem Product Support Engineer
(4,673 Views)
Thanks a lot Brad,
well we r  trying to figure out how-to  with TDM   with our intended purpose
I am working on the teststand side
 Lets see will  keep updated with  any new info.
I tried the ATML plugin  but   we need   the  data  too much customized and  hence   writing the plugin  sounds  the only soln.
(4,660 Views)
