NI TestStand
TS 2016 Step Settings Window not loading, nulled
Suddenly,
Step Settings Window is null & grayed out nothing, its fixed & unmovable in the top left corner.  I was in the middle of debugging, the Step Setting window did not appear after selecting View\Step Setting.
I inadvertently opened TS 2010, closed that then open TS 2016.
Is there a way to reload TS 2016 back to an Init Condition out of the box?
(2,631 Views)
Accepted by topic author richjoh
Run the version selector and select 2016.  This will reset all of the activeX components for that version.
Also, try rebooting your PC.  I've seen this before and that fixed it for me.  (sounds like an IT intern but it worked)
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,616 Views)
