NI TestStand
TS_Err_ProgramError–(Value: -17001)
this is the error occured when i attend to test the vi .....
the vi is attached below.....
(2,955 Views)
Hi Rajeshg,
Are you having problems with any other VIs or code modules, or just this one?  I've tried your VI in TS 3.1/LV 7.1 and TS 3.5/LV 8.0 and receive no such error.  Is there anything else happening in your sequence?  How is your LV Adapter setup (running through the environment or the Run-Time Engine)?  Please let me know some additional information so we can make sure to get this working for you.  Thanks and have a good one.
(2,938 Views)
