NI TestStand
TS LV step , get parameter value( cluster) with API
Hi
In LV using TS API, how to get the value from a container.
In this example, we want to get Device Name value  ("device-")
how we can have acces of all the cluster value ?
Stuck here !
Thank's for your help
(1,002 Views)
what is the result of your LabVIEW code? Errors? Wrong values?
(961 Views)
no error ...
I have only in the ValueExp  a string "Cluster".
I find the way to acces of cluster structure to get the value of the "Deviev Name filed"
Olivier
(952 Views)
To access the actual value stored in (a component) of a cluster,  you should try to access it via Step.TS..SData.ViCall.Params[‘ParameterName”]. property. IMHO, when using the LabVIEWParameters property, you are accessing more like the definition of the adapter / the interface, not the concrete call
in order to be able to see the TS object in the property browser, go to StationOptions->Preferences->show hidden properties
(937 Views)
