NI TestStand
TS Start up. What is called and in which order?
I've started the thread about the order of loading types here: http://forums.ni.com/t5/NI-TestStand/TS-Types-Order-of-loading/td-p/3055627 but I'd like extend the scope a bit.
What is happening when I open TS Sequence editor? Lets assume I don't call any sequence file and no station model is defined for the station.
Is the FrontEnd Callback sequence called?
Is the Station Callback sequence called?
(4,605 Views)
Hi MimiKLM,
I am an AE from the National Instruments team. I had a look around and it seems that the FrontEnd callback is being executed when you are prompted for the Login details at the start of TS. The StationCallbacks.seq is an Engine Callback which is called at certain points during the execution of your sequences as it seems.
Some useful links to look into this further:
https://www.ni.com/en/support/documentation/supplemental/07/using-callbacks-in-ni-teststand.html
Hope this helps
Kind Regards
National Instruments UK & Ireland
(4,582 Views)
