NI TestStand
[TS2016 / CVI2015] Get and array of strcut from CVI DLL to TestStand array
I have an array of struct containing data in the CVI fucntion. I need to get a copy of these data from the CVI function.
Did any one have an example of this ?
Thanks in advance,
(3,000 Views)
I think the following article from our website will be helpful to what you are looking to do: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kJ23SAE.
Marco C.
Applications Engineering
(2,974 Views)
Accepted by topic author HoussamAz
Thank you MChanchu for your reply.
I solved the problem by adding code on my CVI dll, I used the TestStand API functions to update data array.
(2,941 Views)
