NI TestStand
TSAutoMgr Module has stopped working
Hello Everyone,
We have an application running in Teststand 2012 that crashes about 2 times a week.
Te message on the popup is "TSAutoMgr Module has stopped working" (see image) I can't find any information for this.
Can someone at NI help guiding me to a solution?
Thanks.
(3,273 Views)
That module is primarily used for TestStand synchronization objects that are accessed cross-process (i.e. for synchronization objects with names prefixed with an * or the machine name). You might try monitoring that exe with the task manager and see if the memory usage or some other resource such as handles is perhaps growing unbounded.
(3,233 Views)
