NI TestStand
TSDU VersionString for Package-Based Distriubtuion
Is there a way to use the TSDU Command Line Arguments to set the Deployment Version property?  I've tried using the /versionString argument, but it doesn't seem to take it.  I am wondering if this is an unsupported feature for package-based distributions.
Steven Dusing
CLA, CTA
(1,498 Views)
Accepted by topic author sdusing
After speaking with NI support, they offered this solution, which does appear to work.
When you are configuring your deployment, first select "MSI-Based Installer" and go to Installer Options > Advanced Options and make sure the Auto-Increment and Lock to Deployment Version checkboxes are not checked.
Then select "Package-Based Distribution" and go to Package Distribution Options -> Configure Package Attributes and make sure the Auto-Increment and Lock to Deployment Version checkboxes are not checked.
Now the following command line script works
"C:\Program Files\National Instruments\TestStand 2021\Bin\BuildTSD.exe" /versionString "1.2.3.4" "C:\Projects\MyCustom.tsd"
Steven Dusing
CLA, CTA
(1,250 Views)
