NI TestStand
Target File and Source Settings greyed out
Hi All,
Having some issues trying to use the property loader in NI TestStand 2019,  the target file and source settings are greyed out, could any help me understand why ?
I have the path to my source file entered,  and I used the export tool to create it.
James
(1,563 Views)
Hi James26,
Could you please share the screen that shows this. This will give a clearer picture of your problem.
Best Regards,
Edgar Umrikyan.
(1,515 Views)
Hi Edgar,
Thanks for your response, please find attached a screenshot.
James
(1,512 Views)
Hello James,
If you mean this part, so it is saving in this part to the variable sub-window. You can just change the Sequence file by disabling the "Use Current File" and mention the file that you want.
More information you can find by this reference: Property Loader Step - TestStand 2019 Help - National Instruments (ni.com)
And this one I think can be useful: Import Properties from Excel in TestStand using Property Loader Step - National Instruments (ni.com)
Best Regards,
Edgar Umrikyan.
(1,484 Views)
