NI TestStand
Tclk Session Reference Error
I am trying to pass Tclk Session references between steps in teststand. Whenever I try using this data type in teststand I get an error.
What am I doing wrong?
Brian
(3,749 Views)
Also, the TestStand Instrument I/O VIs do not seem to work using Tclk Session reference.
(3,742 Views)
You appear to be missing the tclksessionNoArray.vi from your sequence.  Can you attach that file?
Allen P.
NI
(3,738 Views)
(3,735 Views)
I still cant figure out why you cant pass Tclk sessions references between steps in Teststand but I am using a work around by passing the session handle and using the HSDIO get session reference vi to get the tclk session reference.
If anyone know how to pass tclk session I would like to know, or why you cant pass them if thats the case?
Brian
(3,699 Views)
Hi Brian,
It looks like there may be a problem with the LabVIEW ActiveX adapter recognizing the type of that reference.  I am looking more into this and will let you know what I find.  I believe that we may be able to typecast the reference to a U32 and pass that value into TestStand.  You may want to try this and as soon as I determine what is happening I will let you know.
Caroline Tipton
Data Management Product Manager
(3,696 Views)
