NI TestStand
TempReport html file - results from XML and expand style sheet
I run Teststand sequences that generate XML using the expand.xsl style sheet. I notice that during execution a TempReport.html file is generated. The file contains(what appears to be) the result of the style sheet "interpreting" the
XML file.  I LIKE the html file format that has expandable selection tabs and so I want to keep that.     The thing is, the TempReport is removed when the sequence is terminated.
How to I tell Teststand to Keep the html file when execution ends.
(3,056 Views)
Hi markwell99
I came here trying to find a better solution, however I think I have a way to get this HTML "expandable" report. During or after the execution, if you go to the report tab, you will see that a temp report exactly like you said, will be available in the folder. So if you move that file to another place or just rename it, you will be able to keep it. I must say that if you just close the report tab in TestStand, this tmp file will be gone. I just wonder why this solution isn't available as a regular reporting option...
(2,601 Views)
