NI TestStand
Termination does not stop at 'cleanup'
HI,
I was under the impression that a Termination act on a sequence will throw it through the cleanup procedure of the sequence.....am I right?
Anyway, it doesn't happen to here.  I put a break in both the main sequence cleanup and the sub-sequence clanup.
Is something wrong?   Is it possible that a turned a parameter off?
Rafi
(3,003 Views)
It should do, switch on Tracing while terminating, then put a break point on one of the steps in the cleanup to see if you stop in any of the cleanups.
It should only be the Abort action that doesn't do the Cleanups.
Regards
Ray Farmer
Regards
Ray Farmer
(2,992 Views)
